Originally Posted by
fromdeeeast
Yer was about to say the same thing.
Also VeYzZiI you can't just put on a turbo kit and expect it work, you said that your not gonna bother on the "greenies". You can run a turbo kit off stock injectors and no aftermarket ECU. Well you could but it would shit itself. Not trying to sound rude but a bit more research is needed.
As zhong said get the ebay kit and use bits and pieces. Like the FMIC, piping, clamps, lines etc. You said you know liverpool exhausts so thats a massive advantage to getting an awesome exhaust and manifold made up which ebay kit one is shit. Turbo, get a nice piece of gear, not really sure what would be suited for the s2000, but a gt3071r or something similar usually does well on most 4 cylinder engines.
And most importantly get it tuned properly and running safe. Its all the tuner and how well everything is sorted, coz what will cause an engine to go 'bang' is messed air flow ratios, which would cause the car to run lean.
So yer it isn't too difficult or confusing just dont cheap out on the right things.
Best of luck!
