i have two recaros, and both of them cant recline/adjusted, the back just swings forward and stays there..is this expensive to repair?
thanks
thanks
and yes i have looked in the search and couldnt find anything :(
bumppp
without more information it's hard to give specific advice unless someone has encountered this specific problem before
but call up someone that works with upholstery, maybe try body works shops too, in the meantime just to get an idea for price.
just hit google up i'm sure you'll find some nearby.
good luck
See in the pic at the bottom right corner , theres a big black knob you use to adjust.
Is that what you are using?
http://www.motorsportseats.com/recar...inyl_index.jpg
LOL
this is funny
did u happen to buy these from hontoys at smithfield, the two black sr4s
probably missing the locking tab right at the bottom corner, looks like a hook
the dark black hook in the corner locks it in place http://www.scribd.com/doc/37355628/Recaro-Repair-Guide
http://htmlimg4.scribdassets.com/4xn...1bc42f/000.jpg
http://htmlimg4.scribdassets.com/4xn...357fc5/000.jpg
more likely he was just using the top lever and not using the bottom knob to adjust the seat.
LOL
^^^hahahhah, i can see how this could happen, but ill give the benefit of the doubt to the guy, and see if he shows up to tell us more
He hasn't showed up for 3 days, I think he was using the quick release latch up the top and is now embarrassed about it lol.
thanks, ill have a look next time i see, it as its not at home! :(
So wat was the actual problem then?
