Hey guys
Just wondering how to remove a fog light bulb as i was looking at getting some brighter ones.
I have looked for threads about this but can't exactly find one. Step by step would help :D
Hey guys
I replaced mine by taking off the front bumper (I had already taken it off to install the CAI), not sure if there is a better method out there..
oh alright, so did you put brighter ones in? i should be getting my K&N Typhoon in the next week or so :D
Yup, from memory the stock foglights are H11 socket bulbs. You can put H9 bulbs in with a little modification, they are a lot brighter than the H11s. I have a set of white/blueish H9 on mine!
for pre-faced versions then there is a bolt holding it in. If you look through the bottom of you bumper between the gap, on either side you will see a little hole you can poke a screw driver through. And if you poke your hand through the middle gap of your bumper and align up with the hole, then you will feel for that bolt. You need a philips screwdriver. Becareful not to let that bolt fall down to your undertray cos it will be a Bit^h to find so take your time, preferbly one hand feeling and holding the bolt while you un-screw through that little hole. You'll know what i mean.
Once the bolt is out the fog light will be loose and u can pretty much push it abit from behind and it will come out.
ahh ok thanks i'll try that bro :D
have you repalced your fogs?
No Problems, yep I had changed my fogs lights before on my old 04 model which is what you have. I've converted them to H9's which are brighter as discussed by one the other members above. They are orginally H11.
Heres the DIY from one of the members that might be a good read.
http://www.ozhonda.com/forum/showthread.php?59500
thanks again :D just trying to figure out the screw you're tlaking about :S haha
You wont actually see the screw... you will see on the hole to poke a screwdriver in..
Might be leadiing you a stray...
Basically if you look under your grill there is a large rectangular ventalation vents for your radiator, on either side towards your fog lights you will see a hole on the side of the vent. So not looking straight into the radiator but to the side...
hope this makes sense..
http://img571.imageshack.us/img571/1994/67902177.jpg
Heres a pic that might make it easier to find it...whereas the red line represents where the screws are.
ahhh yeah that makes it alot clearer..i was looking underneath the car bahaha :D
i'll have a look now and let you know if i'm stilll confused haha
it would help to take the plastic cover thing off the car right? like under the bumper
i think i felt a bolt for a second but i'm finding it hard! may as well take the bumper off i think? :S
yay i think i found it properly..you have to get the screwdriver in that hole at an angle aye? i'm just abit worried about how i'm gonna get it back in there? :S was it trial and error for you to get the screw back in or are you just pro? haha :D
Hahaha...thats why u get a magnetic screw tip screwdriver and shove your other hand in the gap of the bumper to guide it in.... na no pro.... just been fiddling around... and no need to take anything else off...that bolt is the only thing holding it in... and yes it is in abit of an angle..
haha yeah that would be handy..i think i might take the bumper off..just so i know how to anyways :D
