Originally Posted by
dinorider
This was EXACTLY what happened to me way back in 2000, in my DA1 Integra!
I felt the pedal getting spongy the day before, but didn't think much of it. Then as I was driving along, came to a roundabout at about 50km/h, pressed brakes, felt the normal resistance, then suddenly the pedal lost all resistance and shot straight to the floor. I nearly shat myself.
Luckily the roundabout have very little traffic. I flipped on the hazard lights, pulled the handbrake hard and pulled over to the side. That was bloody lucky. Because I was about to go on the freeway. If I had lost brakes at 100/km/h... Well I would probably be dead.
Tow truck came. My mechanic was at a loss because the brake master cylinder and booster were fine. Then he found that the front tyre had rubbed through the brake hose because some noob mechanic has mangled the hose mounts on the front shock absorber when the shock was replaced by the car's previous owner.
So for others reading, this problem is not a one-off. Check your cars.
