civic with b16b overheating
		Help!!!
guys, i think i have got an oveheating problem on my b16b. temp gauge goes up after driving for over 30mins but only when car is in traffic but not when car is moving also when air con is turned on. fan comes on when it suppose too, no major leaks (except very very little wet spot under the thermostat. i've replaced the thermostat and the switch. all hoses are fine. no coolant lost. I've bleed the coolant 3times. What can the problem be? can the wet spot cause under the thermostat cause the temp to go up?
thanks
