Brake light problem
hey fellas,
got a serious problem here, my brake lights on my EG civic sedan aitn working... when i turn on my headlights the tail lights turn on, but if i hit the brake, my brake light does not go on and my tail lights do not get brighter... so, in the day time, i have no brake lights !!! ive checked all bulbs and they are fine... what could be the problem? i tried to check fuses but i have no idea what fuse to check... but they all seem to be fine..
need help on this asap guys!!
thanks in advance
im no electrical guru, but how do the wires look?
are you bulbs black? try to get a new bulb from somewhere and try it again.
otherwise it sounds u have a relay problem.
my bulbs are fine man... they all work... i kno this from when i turn on my headlights... is there like nething connected to the brake to make the lights shine brighter?
lol... u know ur ment to use hand signals now :) :p
the bulb for the brake is divided into two parts, one that shines which ur beam on and one that shines when u press the brake, take the bulb out and observe it, u'll see what i mean
ok ill check and get back to u... any other resolutions??
read the fuse label and look for the brake light one/rear lights or something...
check the fuse other just remove all and see which ones busted haha
hmm ok.. any other ideas?
Change the bulbs and see what happens because 99.9% of the time this is the problem. The other thing it could be is the activator switch on the brake pedal. This may be faulty so when you press the brake the switch is not activating, giving no brake lights.
Hope this helps.
your bulb could still be at fault. if on one of them the tail light filament is touching the brake light filament then power could be driven to the brake light circuit.
aslo sound slike your brake light switch/fuse could be faulty.
I reckon you've got single filament bulbs in there. Did you get them from SuperCheap, cause if I remember correctly, they don't stock dual filament bulbs.
