This link speaks for itself.
http://www.angelfire.com/dc/integra/rsxengine.html
revving it at 9.770 rpm for 1.1 secs. oh well hopefully he replaces da enginge wit a vtec:)
i was thinking that if you down shift from 5th to 3rd.. your gears would crunch.. and not alllowing you to do such thing. .guess i was rong.. and this guy.. NUTS ?!
**Thread Moved**
I thought there would have been a rev limitered at red line to stop the car from reving? Or is that only limited to some cars?
if your gearbox is pushing the car going on the speed the car travels, unless you put your foot on the clutch the gearbox will drive the crank to what ever speed it needs to go to.. If that makes sence. the Rev-limiter doesnt work on downshifts because the rev's are driveline-speed related rather than fuel or throttle related..
:thumbsup: :thumbsup: :thumbsup: Ta, that kind of explains the rev limiter part but doesnt explain goin from 5-1st LO and also bein at 9rpm for 1.1second when the redline is at 6. sumfin rpm.
work it out in your car 120kmh in 5th might be 3500rpm redline in 1st lets you do 55kmh.. to do 100-120 kmh in 1st you'd need to pull 12,000rpm or more.. so they car slams the vavles until the break, the rods break, the pistons crack and the car over 1-2 seconds drops back onto the rev counter.
I can say I have hit 3rd instead of 5th down the strip, but I knew I had before my foot was off the clutch. I think the needle just passed 10,000rpm before I had my foot back on the clutch..
ive got this on video
lol
i've miss-shifted at 180-odd in 4th to 3rd before...
the tacho needle when off the dial and i was sure that i'd broken something, but it was all good :)
same, 3rd to 2nd in mine just over 100km/h i think
needle went to 8000rpm
theres a site with photos of a honda engine that did something like 16,000 rpm after a misshift. i have a feeling it was a RSX too. engine just went pop. theres photos of the oil sump full of chunky bits and the pistons look like potatos.
ive seen that too... couldnt believe what i saw cos the pistons had turned into found metal blobsQuote:
Originally Posted by CTR Coupe
if he manage to get it into 1st at that speed and rpm it would have beenvery hard to pull the lever out of gear because of the force on the gearing. More revs you have the harder the shifts get.Quote:
Originally Posted by Sp3rMz
NOOB QUEST: Isnt it not "healthy" to down shift anyway?... like even when you are cruisin along n sum chump wants to go ya n u shift down a gear to engage VTEC (even if u rev match), theoretically isnt it not good for the car?...
I AM GUESSING YOU HAVE NO IDEA WAT A RSX IS , it would of had a k20 vtec motor, just not as hard tuned as the type r versionsQuote:
Originally Posted by v3rdino
hahaha it took me to this post to realise what v3rdino said lol :D
vtec y0!
and jules its fine to downshift as long as u dont do it like the chump in the link hehehe
if into the right gear it will be fine
16k rpm? shit thats nearly as much as a rotor man!!! no wonder it blew rofl
would be sad to blow an engine like that tho
guess i should stop engine breaking...Quote:
Originally Posted by Non Vtec
how do you shift down from 5th to 1st at that speed... im havin trouble tryin to shift down 2nd to 1st at 30km/hr... it only goes in easy when it is at very low speed
not all drivers are good drivers.
THe idiot was prob street racing, not dragging and tryed to downshift for a corner, n just stuffed it up
note to self, do not mis shift frmo 5th to 1st, lol but yeh as redliner said, the shift isnt easy to go in unless your doing less than 30km/h youd obviously know somethings abit off if your goin that fast trying to go into 1st.
Yeah, and they keep making better and better gearboxes that make it so easy to pick any gear you want. I have done a 3rd into 2nd UP shift before and the tacho went off the dial for a split second. I clutched in pretty quickly. The engine is still ok though, I checked the compression and dynoed it and it was fine.
