is there anything i need 2 be aware of b4 i buy it from ebay US?
the 1 im getting is p06 converted to vtec so its pretty much p28 and with hondata in it.
is it diff from aus sellers ecu?
cheers.
cheers.
id also like to know this, with just buyng the hondata unit itself from the states.
subscribed.
Yonas from JDMyard uses the usdm ecu and usdm s300, he said he had no problems. plug and play.
Usdm hondata should be fine with aus ecu? And tuning all good?
Mind you it could have been the company just wanting to make more money
Wasn't any traders on here btw
I have installed many US S300's into AUDM ans JDM ECU's without any issues.
ok thanks for info. looks like i'll grab it.
getting the p28 with hondata s300 already in it so plug n play.
getting ecu and hondata seperate is cheaper abit. but just to be safe i'll get the completed ecu, plus n play. in case bit of issues.
only problem is i cant find a d15b7 basemap in the hondata software, but i assume that d16z6 is same shit just with vtec.so i just disable it.
good luck with it :thumbsup:
i cant say on the base map side things, i dont wanna mislead you.
so r u getting s300 complete ecu or just the unit only?
Mugen_R can get great deals for hondata s300, from japan.
give him a pm
From Japan?... You mean the US?
Just remember, they dont go in all ecu's though peeps. They can be had for cheaper than 495 also, was that with shipping?
what u mean doesnt go in all ecu?
shipping was 60 if it was the same one on ebay.
theres also cheaper ones on a few websites not ebay tho.
few good rep site examples:
http://www.xenocron.com/hondata-hond...s-c-42_56.html
http://cgi.ebay.com.au/Hondata-S300-...item43a5c6d5db
http://www.phearable.net/shoppingcar...s-c-23_25.html
http://www.hamotorsports.com/hondatas300.html
still more sites but their on my desktop pc, and cbf turning that shit on takes 30min to load.
but i still buy from ebay least u get protection. just to be safe than sorry.lol
S300 will fit a USDM AUDM and EUDM ( non JDM ) ECU. the ECU needs to be preped. Compatible ECUs are
P06, P07, P08, P28, P30, P72, P75, PR4
S300J is ment for the JDM type ECU, so it can fit
P07, P08, P29, P30, P72, P75
I might haved missed an ECU moddle and the ECU's need to be modified to accept the S300. some ECU's listed above do not have VTEC or 4Wire O2 Heater support, These features are added when the ECU is made S300 ready. also you can add PWM for boost/NOS controll and IAB support to any of the above ECU's that dont already have it.
Prelude and Accord ECU's will not accept any Hondata Unit. The OBDI ECU must have the M66X207 series MCU in order to be Hondata compatible.
All the above goes for using Crome, Hondata, Neptune, Uberdata, hondalogger ect. all the same
I bought a new S300 unit from bisimoto USA just recently for $526. just waiting on it to arrive, postage wasn't bad, $59 for international express. :)
Getting adrian at TODA to install it to my P72 and tune very soon. Will post results when it's done!
dont go ebay just get it from a shop in the states called phearable they can put the s300 in an p72 ecu for you or just the basic one without cost.
i got one from them and had no hassles. they can even give you a basic map until you get it fully tuned...just tell them what mods you have and they go from there
i see, tho still searching for a base map for d15b7 for hondata software.
just got there site mate.
http://www.phearable.net/shoppingcar...ages-p-39.html
you said its no extra to get them to put it in an ecu? your own ecu? they supply an ecu?
there are a few options there .. they can install for eg. into an obd1 vtec ecu for +$110.. or into obd2 ecu for $295.
kinda confusing...
would i want to get installed into obd2 ecu for dc2r or obd1 then get a conversion harness :S
yes turbo kit is installed.
i was thinking similar idea to this, but in this way:
unplug hondata unit from the p28 ecu and just used the 28pin chip and have sum1 tuned a base map on crome or sumshit like that according to my setup.
that way least i can drive the car with more safely then now.
coz i dont really want to tune it yet bcoz it will be a waste of money now, since im building a d16 engine on the side.
so was hoping when the d16 build is finish i dropped it in and bring it to the tuner have em do their thing. better than paying twice for a tuned.
which cost both my balls sack.
if u know what i mean.
PM price on how much your installation and tune is and also any mods you are running please :)Quote:
want to get hondata sometime soon
is any1 using boost control solenoid package?
Just ordered one for a mate. S300 + ECU landed $700 AUD. Plug and play no hassles. Pm ill guide you in the right direction.
little update i got ecu 2day.
