Originally Posted by
vinnY
well you were right, ignition is fine
I heard the starter motor catch and spin a bit but it stopped and just started to have single ticks again
it's as if it has enough juice to make the solenoid function but not enough juice to crank it over
getting a constant 12.72v off and it stops to about 11.3v on start now
so for the out of car tests, it's basically applying the neg terminal where the 12v line usually goes and touching the pos terminal to the starter solenoid to see if it makes the starter pinion pop out?
