So straight to the point,
How the f*** do you get a sump gasket to seal properly?!
I've been through two new OEM gaskets now trying to get it to seal.
so I've tried using Ultra Copper and I've tried OEM sealant from honda.
I've done everything by the book, the pattern and torque specs. and no matter what I do the bloody rubber piece of s*** distorts and leaks.
Even with less torque then is recommended, and if I back it off to the point where there is no distortion, it just leaks out the bolt holes cause they aren't tight enough.
I'm going in for another attempt with a new gasket on wednesday, this time using a heavy duty sealant (permatex no. 2) on both sides and I'm thinking I'll just do up the bolts enough to squeeze the gasket, then leave it for most of the day to let the sealant begin to vulcanize, then torque it to spec and leave it overnight to fully vulcanize before re-filling it with oil the next day.
any input on this way of going about it? any tips or secrets to getting this bastard to stay shut with no leaks? anyones input is very welcome.
car is a DC2 Vti-R.
thanks guys. :)
