hey guys my first write up , so please don't hate . I've gone through a few sets of DIY spray can wheels that have turned out really nice, some didn't turn out so good (first sets) but it's all about practice makes perfect. Colors i've gone through matt black,gloss black, pearl white, emerald green, international orange, and sky blue.
Pretty much my aim is to save you money while giving you a refreshing looking to your wheels , to have some super sexy wheels . Spraying wheels can add a whole new look and feel to your car.
Now depending on what rim you want to spray and how you want to spray it , theres a few ways. If you have wheels with lip and you want to keep the silver lip then you can either a)tape up the lip or b)use a deck of cards (this writeup). If you don't care about the lip or don't have one and don't mind spraying over it then your fine. Also to make it easier if your rims are already off the tyre then thats even better (no over spray on tyre, but if you overspray it's fine) Okay so lets get started. I'll be doing my wheels gloss black with a polished lip.
TAKE WHEELS OFF THE CARhttp://i1239.photobucket.com/albums/...h_IMG_1016.jpg
30mm spacers :zip:
Things you'll need:
- newspaper (few sheets) - i used 10
- masking tape or deck or playing cards
http://i1239.photobucket.com/albums/...h_IMG_1011.jpg- soap , water , bucket, sponge
- 1 x can degreaser (depending on how dirty your wheels are)
- few dry rags (clean)
- toothbrush (optional)
- 2 x paint (choice of color) - try to get a better quality paint
- 2 x can of primer (white or grey)
- 1 x can of tyre shine (optional)
- sunlight (try to get a sunny day for better result)
Preparation:
- Spray some degreaser on your rim to get all the muck off (leave on for 2 minutes, hose off)
- Get your bucket of soapy water , plop sponge in , and give your rims a nice scrub down to remove all the other dirt left behind (try to get your wheel as clean as possible)
http://i1239.photobucket.com/albums/...h_IMG_1009.jpg- Get the rag and dry your wheel (try to dry as best you can , get rid of all water) - use sunlight to your advantage to help dry out the rim
http://i1239.photobucket.com/albums/...h_IMG_1014.jpg
Method:
1.Lay newspaper on the area your spraying , lay rim onto newspaper (flat)
http://i1239.photobucket.com/albums/...h_IMG_1010.jpg
2.Either tape up the lip that you don't want to spray OR use a deck of playing cards and place them inside the lip , all around the rim (refer to picture) if using cards make sure you overlap them and don't leave any gaps
http://i1239.photobucket.com/albums/...h_IMG_1017.jpg
3.Shake up primer car, spray a light layer all over the rim (allow 3-5 minutes to dry)
4.Repeat above primer step 3-4 times (allow 3-5 minutes drying time for each layer) NOTE: spray evenly
http://i1239.photobucket.com/albums/...h_IMG_1015.jpg
5.Shake up your chosen color of paint can, spray a light nice even layer on the rim
6.copy above step (allowing 3-5 minutes to dry each layer) and do 3-4 layers
http://i1239.photobucket.com/albums/...h_IMG_1019.jpg
7.OPTIONAL: for a glossier look , spray a LIGHT layer of tyre shine over the last coat of paint (while its drying)
9.Remove cards from rim (resuse cards for next wheel) Set rim aside and let it dry in the sun (keep away from dust) , move onto next wheel
http://i1239.photobucket.com/albums/...h_IMG_1020.jpg
10.Copy step 1-9 for your other rims
If you over spray onto your tyre simply grab a little methylated spririts/kerosone on a rag and wipe it away (don't rub too hard).
BEFORE: (look closer to the lip paint fade)
http://i1239.photobucket.com/albums/...h_IMG_1008.jpg
AFTER:
NOTE: i got a bad camera guys ):
Also if you want your lip to look a bit more sparkley just give it clean when all the paint is dry , and use some light sandpaper to go over it while washing with soap and water at the same time. Finnish off with metal polish.
Thats pretty much it guys, hope this helps whoever wants to try it. In my experience the tyre shine before the last layer of paints sets really brings out the gloss. Feel free to comment .
Goodluck and have fun.
