kinda annoying so wana try find the cause of it
any help would be great
cheers
cheers
maybe even put this is all motor section if needed
What 'buzz'?
Is this a noise coming from the engine bay? Exhaust?
Neeeeed info buddy
what?
did you turn it off?
its your vtec kicking in
tighten you number plates
tighten them boltssss
Get a v8?
Its hard for us to solve a buzz issue through the net though seriously :)
Wear ear muffs before hitting VTEC. goddamnit we should launch a class action lawsuit against Honda for not warning us how frigging loud VTEC is. It's like listening to classical music that suddenly changes to hardcore death metal.
Car ? Motor ? Mounts ? Stereo ?
Buzz could be anything.
its from exhaust under load
sound is typical ricer fart can kinda buzzing sound that you hear from 90% of hondas
is it due to dead/poor quality muffler?
system is a custom 3 inch header back
still has cat
1 large res 1 small res and 1 muffler at the back
Might be a cracked weld,rust hole or as you say burned out muffler
i think it's one of the exhaust hangers vibrating. I get that too
Just curious what you're running to require such a massive exhaust?
The ricer 'fart can' noise is because people put an exhaust on that has not alot of sound resonating qualitys (Simply adding a cannon also has this effect)
So, downsize your exhaust, put a Resonator in, or live with the noise.
Could also be your heat shielding above your muffler/exhaust piping.. With alot of noise they will vibrate and piss you off.
thanks guys
i'll have a closer look next time to check if there is any holes or broken hangers
i already welded up one hole a couple of weeks ago so maybe theres another
might check the cat too if that has collapsed
jccck: where is the heat shielding your talkin bout?
on bolted to the body in the tunnel?
