Hey guys,
I noticed that the AUDM integra type r have 141kw and the JDMs have 147kw,now the engines specs seem identical so is the only difference the ecu and the mapping? if so can a jdm ecu be swapped over into an audm for extra power?
thanks
Hey guys,
thanks
They have better headers aswell
better fuel in japan, which compliments the tune
better header/exhaust/cat
And iirc, they have a slightly higher compression ratio.
didnt v power used to be 100?? why cant we have higher octane, higherr!!!
100 octane is where its at!
and also with any other car in australia its been watered down with minor ecu changes from factory to suit our climate or what not.
we got 98 atleast we dont have a max of 91 or something in most states in america
lol poor usa how do they have performance cars :S
I think you all need to read up on Octane rating.
And U.S.A fuel is the same as ours they don't use the RON rating they use ALI I think.
couldnt i just get a a full exhaust system,plug the jdm computer in and use 98 premium fuel with octane booster? would that work?
need a tune too.
where can i get hondata from? and how much is it? are they similar to like a apexi power fc?
Op, for the money you spend on a jdm ecu, jdm 4-1 (98spec) headers and cat (im pretty sure the cat is exactly the same 2.25" and stainless steel) u may aswell put in a bit extra and get ur self some used good aftermarket headers with a 100cel cat. Keep ur audm ecu, with out a tune u will have more then 147 at the flywheel.
Then free up ur cat back with a mugen twinloop or wateva exhaust u want. Then Buy urself a hondata and tune it and ur lookin at 120-130 kw atw, which would prbz be around 175-180kw at the fly
http://www.ebay.com.au/itm/Hondata-S...item19c9359350
if you need an ecu
http://www.ebay.com.au/itm/BLACK-ECU...item20be025828
might also need od2 to obd1
http://www.ebay.com.au/itm/OBD2A-OBD...item41571090b3
thanks for all the info guys, given me something to look into
I ment cat-back* my bad
Ah okay. I've got both jdm and adm b pipes here. Yet to do a full measure up, but I suspect they are the same other than the obvious length difference and the extra resonator on the jdm
audm catback is stainless.
Think he needs a neg rep for false info hmm hmmm
Looks stainless to me. Also pretty sure audm and jdm axle backs are exactly the same in length, material and design
Vpower Racing was 100 octane by adding 5% ethanol to 98 petrol. We didn't want to pay more for 100 octane where all they did was add more ethanol. Low sales = stop selling the petrol
Different rating used in the US. Their equivalent for our 91 is their 87, our 95 is their 91 and our 98 is their 93/94.
get ridd of the cat alltogether
^ and smell like shit everyday after driving your car, be exposed to be fined by police/epa $15,000.. no thanks
^agree with this guy, constantly smelling fuel/fumes= do not want.
Plus it made a considerable difference in the raspyness (is that even a word?) of your exhaust note i found after removing mine in my old b18c7.
Does sound more raspy yes, and i found an increase power in vtec.
Umad did ur car go more quite afta de-cat ? (as in vtec crossover wasnt as beefy and loud)
tinny?
the tiny exhaust makes quite a sound when you get ridd of cat alltogether
its really the jdm 4-1 exhaust header that makes the power difference to our aussie models
if you compare them side by side you will laugh at the aussie shit spec exhaust manifold
no, remove the cat, open you rubbish bin and put it in there. then fit a straight thu pipe lol.. nah you can just punch out the standad cat so it looks like its thee but if you exhausts gets probed by the epa expect 1k fine per cyclinder. just tell em your only running on 1 cyclinder haha
