Hey guys, I am thinking about forging my B16a2 with CP pistons and eagle rods because one of my pistons are cracked. As my mechanic told me I have to hone my block down to fit the forged pistons which is the exact same sizes to the OEM pistons(81 mm) is that true? is it better to go oversized bore? and if I were to get the pistons compression ratio 10.5:1 would I need to retune my car cause the standard one is 10.2:1 which is not much of a difference so I'm guessing I do not need to retune it. I'm not planning to turbo the car or anything though so yeah can you guys give me suggestions of what I should do? :) Thankss
