What's the best out there? Or is there any that will hold up to f1 type of engine speeds?
Or as close to it, if possible. I've heard of rods stretching from high g loads.
Rods are not the only consideration at that RPM. Your valve springs can't keep up, and you'll end up with valve float. F1 cars use pneumatic valves to overcome this problem.
I know this but my question remains un answered.
put a motorbike engine in if u want that kind of rpm
Still un answered.
pm adrain from toda
of course there is. They have them in F1s dont they? They use titanium alloys.
but what motor is this for?
Trick Titanium, Pankyl & Arrow to name a few, what motor, application & budget?
The heavier the rod the stronger the rod, but does weight concern you? If its a race motor and getting stripped frequently and you have a ton of money as you normally throw them at intervals then aluminium rods might suit, there are heaps of people who make them, but only a certain few make good ones.
Maybe consult your engine builder?
If the budget is win... Pankl. Nuf said...
^^^ Pankl produce F1 Rods.
No worries, let us know when you drop 20k on a set of rods seeing you need the worlds best rods for your build. Go the forums!
Great I ask a question. And all I get is key board warriors?
http://www.shop-pankl.com/fileadmin/...tpleuel_01.pnghttp://www.pankl.com/uploads/pics/engine.jpg
http://www.f1technical.net/forum/vie...php?f=4&t=9346
That'll keep you busy for a while :)
Thanks.
No specific's.
That was an awesome read, thanks alot TODA au
