Shorter rack ends/tie rods for EF Civic available?
Hey guys,
I've got an EF9 (with a B18 conversion - if that makes a difference?) and I've just installed these camber adjustment arms (http://www.skunk2.com/EF_camber_kit_...v2_retail.html).
After I put these in I noticed I had crazy toe out so I had to wind the toe back by eye until I could get an alignment done today.
At today's alignment, I had new tie rod ends installed at the same time as my old ones had some play in them. The tyre shop just got AUDM ED tie rod ends as directed by me as I assumed they should be the same as the JDM EF9 tie rod ends. I now know this is not the case and the JDM ends are shorter. I only know this now after reading some threads on the EF9 because I have a problem where I cannot run any negative camber with reasonable toe as there is no more thread on the rack end/tie rod.
Basically on -1.5 degrees camber, the most toe I could run is ~45mm toe in because there is no more thread on the rack end for the tie rod end to turn into. This is obviously because the AUDM/USDM tie rod end is longer than the JDM one. Seems like the previous owner didn't know this because the ones taken out of the car are the same length as the new ones put in.
I'm looking for a solution so I can run some proper alignment settings. I don't want to order a JDM tie rod end because I've already got these AUDM ones. I'm looking more for a way to shorten the rack end or find out if there are any shorter rack ends available on the market or even off another model Honda that would fit?
If anyone has any info or has another idea on how I can fix this it would be much appreciated. Thanks :)
TL;DR I need help in shortening my rack end/tie rod (NOT the tie rod end), or finding out if there are shorter ones available on the market/off a different model Honda that will fit my EF9.
