Hi guys, I'm confusing is the EM1 strut bar(front and rear) fit EK4 as well?
Can anyone tell me about that?
Thanks alot!
Thanks alot!
Yes it will fit for sure
Numerous parts on a EM will fit compatiable with other models. For example various EK / EM / EJ parts can be replaced easily. Strut is one of them.
Thank you so much for the information!
BTW: is it there any difference between between the pre-facelift and facelift model on struct bars?
Thanks again!
EK1 pre-facelift doesn't have the studs to mount the factory EM1 or EK9 strut brace, pretty sure the EK4 face lift does have them though...
If you don't have the studs then you have to get a brace that mounts on the top of the shock/strut rather than the strut tower
Yes, it will.
EK4 should already have the same strut bar, why doesn't ur Ek4 have one?
correct me if im wrong
If it doesn't have the studs it should have grommets and you can just byo bolt
EK1 - easy job to make the em1 strut bar fit.
If u dont have the bolts then just drill the holes as they are pre-punctured on the strut chassis tower then install the em1 oem strut bar using the bolts of your choice
Ive got one selling if ur keen.
Are there many benefits of an aftermarket strut brace which mount on top of the shocks/strut compared with the stock brace??
I've got an EK4 with a stock brace and am thinking of replacing or doubling up if the shapes permit.
Any thoughts?
Cheers
EK/EM/EJ/EG/EH/DC2/4 are interchangeable
I got one for sale... PM
