Hi - long time reader, long time absentee. I'm back at OzHonda with my new old 2000 Ek1.
Looking for advice on maintaining an older car that isn't worth commercially servicing.
Cheers!
doktarfischer
Cheers!
doktarfischer
read service manual.
use google for service manual.
or
pm members here for quick backyard jobs
thanks for the advice... I just had a service done and the mechanic came back with the following recommendations for next service:
Cam belt ($700)
Rear brake shoes ($400)
Rear drums machined ($150)
Trailing arm bushings ($660)
Lower engine mount replaced ($520)
Rocket cover gasket ($150)
all up this is $2580 plus cost of next service, or half the value of the car. at the moment i'm having a look online at DIY for various things but have no experience atm. i'm considering replacing drums with discs rather than spend the money on new drums.
it will be a steep learning curve but thats where the fun is =)
http://img220.imageshack.us/img220/2346/dsc037962.jpg
welcome abourd to ozhonda!!
awesome.. that gives me some confidence :)
do any of these replacements require a mechanic to sign off? esp swapping to discs on rear
EDIT: Just had a look at some prices on www.hondapartsnow.com which seem quite decent - is this site trustworthy?
depends on why you want a sign off.
for documentation of selling car in future or just own assurance
just for legal requirements if any
timing belt isn't hard.. It's just a major pain in the ass. Fiddly and small working space.
i found some info on this thread about converting from drums to discs. i've had a look on this website for some prices for parts. is this site well known/trusted?
also the list mentions you need EK1 trailing arms - does that mean the factory ones on my car are suitable and don't need to be replaced? same goes for handbrake line/prop valve?
EDIT: another thing when looking at parts, the rocker cover gasket only appears to be sold in a "gasket kit".. is this necessary or can i purchase the gasket by itself?
Go to honda or a parts place.. they'll hook you up. Honda will be the more expensive option, probably $80+ and the parts place anywhere between $20-70
yeah i will drop by a parts store if i can find one nearby and see what prices are like locally. if they aren't too bad that will save a fair bit of time.
for this i will have to go through forums as i don't know what part numbers i need for a conversion... same with the disc hub assembly.
will do... i don't mind not using OEM as resale value isn't an issue but are there any parts that OEM is a must for quality/safety, etc?
