Clutch Masters (Australia's Authorised Dealer)
We are the authorised dealer of Clutch Masters for Australia . Clutch Masters offers clutches for any car and any spec. . Clutch Masters has a big variety of clutches from Organic up to Twin disk and can suit any power and application , even if you want high revs . Also Clutch Masters overs a variety in materials . Clutch Masters also offers it's own flywheels .
http://extreme-projectworld.com/imag...ies/345x90.jpg
Furthermore Clutch Masters provides kits also for Hseries engines with Bseries gearbox and Kseries engines with Fseries gearbox .
All Clutch Masters clutch kits come complete with:
Pressure Plate
Clutch Disc
Throw-out Bearing (when applicable)
Pilot Bearing or Bushing (when applicable)
Alignment Tool
Typical benefits of a lightweight flywheel
Reduced mass equals increased acceleration.
A lightweight flywheel works particularly well with turbo-charged engines because it reduces typical turbo lag.
Increased supercharger efficiency due to less parasitic drag on the crank.
Improved mid-range torque in a normally aspirated engine due to not having to overcome the heavy weight of a stock flywheel.
CM uses High Carbon steel for the friction surface. (Replaceable on Aluminum Flywheels)
CM Billet Aluminum and Steel Flywheels meet SFI Spec 1.1 or 1.2
B16/B18/K20A :
Organic Clutch (70% Holding Capacity over stock) 465 $
6-puck rigid ceramic disc/4-puck rigid ceramic disc(Holding capacity 200-400% over stock) 465 $
Sprung full-face Kevlar disc/4-puck ceramic sprung disc/6-puck ceramic sprung disc/Sprung segmented Kevlar disc (70%-170% Holding Capacity over stock) 550 $
Twin Disk kit (Steel flywheel included) 1690$
Bseries Aluminum Flywheel 350$
Bseries Steele Flywheel 350$
Kseries Aluminium Flywheel 430$
Kseries Steele Flywheel 430$
S2000 :
S2000 Aluminium Flywheel 430$
S2000 Steele Flywheel 430$
Organic Clutch (Holding Capacity 70%) 720$
Organic Clutch with Steele Flywheel 1095$
6-puck rigid ceramic disc/4-puck rigid ceramic disc(Holding capacity 200-400% over stock) 720$
6-puck rigid ceramic disc/4-puck rigid ceramic disc with Steele Flywheel 1095$
Sprung full-face Kevlar disc/4-puck ceramic sprung disc/6-puck ceramic sprung disc/Sprung segmented Kevlar disc (70%-170% Holding Capacity over stock) 820$
Prelude 2.2/2.3lt :
Organic Clutch (Holding Capacity 70%) 430$
6-puck rigid ceramic disc/4-puck rigid ceramic disc (Holding capacity 200-400% over stock) 430$
Aluminium Flywheel 380$
Steele Flywheel 380$
If we do not have the product that you want in stock , delivery is approx 5-7 , if in stock at Clutch Masters . If you have any inquiries please feel free to contact us .
All above prices are including GST .
