I couldn't find the jacking points from middle underneath the car. it was just all plastic shield cover.. Thanks!
in your service manual should have one if you got one that is,
the one in manual only shows the jacking points for right and left body side.. couldn't found the one for middle.. :(
When you say middle, are you talking about the front or back?
you can jack the car from the centre of the front and rear. theres also 2 jack points on each side just infront of the rear wheel and behind the front wheel
centre of the front. thx
Look at where the plastic shield is at the front and in the middle is an exposed metal section. That is the subframe and is also your front middle jacking point.
As Aaronng said, it's the same with most cars, you just use the subframe, which basically holds the engine up. It's even got a small hump so it's easily identified. It's not that far in though, behind the radiator and before the oil sump panel. Shouldn't be hard to find. If I had to assume, I'ld say it's about ~40cm in from the front, right in the centre of the car.
i did a google search
here it is
http://img806.imageshack.us/img806/2...jackpoints.jpg
Thanks champs!!
Is the rear one near the tow point?
Found some pics here
The rear one is easy to spot. It's right under the bumper, and looks like a cage where the towbar is meant to be.
