I took a 2000 ITR for a test drive today.
I noticed when I popped the bonnet that it had an import vin attached
to the firewall.
The VIN starts with 6T9.
Any idea why it would have this vin?
to the firewall.
Attached, not stamped?
JDM or audm? Could be import or mod plate related? Picture please.
rebuild scheme from melbourne
6T9REP is a repairable write-off in VIC, imported shell under the rebuild scheme
The above posts seem correct:
http://www.google.com.au/#hl=en&safe...w=1280&bih=827
If it's a 6T9REP or REBU1L then it's a Vic "repairable write off" which means it could be a dodgy import.
Aussie car gets wrecked/written off
JDM parts brought in to "fix" the write off.
Old cars it was a case of submitting "fixed" car to Vic Roads (aka do nothing except switch seat belts and in more recent cars the speedo for odometer readings to match).
Instant "very grey" import.
It's how most JDM EFs got into the country (my old one included).
NSW RTA will not allow you to transfer rego to NSW (unless the system misses the numbers). Wrecking yards in NSW have occasionally received confiscated rebuilds that are to be cut up. I was lucky, I registered my EF before the system went digital.
There's also a chance it might be a stolen car that has been rebirthed via Vic or Qld - unlikely, but it's a practice that took place in the 90s and the loopholes are closing. REVs would miss it and the communication between different states re: VINs was non-existent.
I bought a 6T9REP vehicle recently and it's definitely an import but says its a DA5 and they never came in 4 door...
It was purchased cheap and more so for parts but I have gone through an ID check with TransportSA and they cleared it. Still need to go through roadworthy which I doubt will pass but just want to try and get it registered in SA ( still has Vic rego) for the hell of it!
Not worried about it being allowed registration from the VIN point of view, it's already cleared ID so that part is fine. More worried about the dented rear subframe, lack of door intrusion bars and all those little details...
Then don't buy it.
I've been over the ITR more thoroughly since the initial post. I checked the panel gaps, checked for paint mismatches, body repair & overspray, but could not fault it.
The body, engine & gearbox are definitely AuDM, as I was able to cross check them. It was originally sold new by Trivetts.
Judging from the interior, I think that this was a stolen recovered vehicle, as the interior panels show signs of having been removed sometime in the past.
Also, the Recaros look to be different ages, when comparing them to each other. After all the close examination, it's actually quite a nice example.
It has an impeccable service history, stock standard (apart from the Alpine head unit, and Koni yellow shocks) and it has absolutely no modifications.
