Hi ozh,
Where can i get the plastic sheet for inside the doors?
and the glue aswell.
Thanks.
Hi ozh,
Thanks.
Panel beaters maybe
hoping for brand new ones
I wouldnt bother no1 can see inside your door trims anyway
You could use some tarp. Nice and cheap and easy to find if you need to replace it. Can't really help you on the proper stuff though. Can't imagine it being that much different though.
tried honda?
Glad wrap bro!
Honda will probably have it, or you can just get those clear plastic backdrop things at paint shop and cut to shape and use sikaflex to hold it up.
sikaflex and that plastic sheetin that painters put on the floor for when they paint inside a house :)
whilst you are at it, might as well tape up the rods of the door locks and what not to silence the door.
What about clear contact? At least you can peel it off if need be later
http://image.ssww.com/catimages/SWPA...d=500&CVT=jpeg
Out of curiosity did you remove the old adhesive goo? Our just adding on top?
Sensai is talking about wrapping tape around the rods where they meet either each other or any other panel or part. This will remove most or all the rattles you may have when opening and closing the door or listening to music (within the door only. Won't magically cure rattles in other places lol)
what rods are you refering to?
to get the goo off, if you get a heat gun, maybe a hair dryer, you can actually pry it off, careful not to get to your paint.
for the particularly thick parts, get a flat head and dig it in horizontally and aim for the middle oft he glue - do not touch the metal door, and just progressively push horizontally and the glue will attempt to clump together,
androo nailed it right. also by putting some tape on the door lock connector rods, the noise the door makes when it locks is softened too.
are you refering to the metal lines that connect the locking mechanism?
yup thats it. when i had my door cards off, i was too lazy to do a proper soundproof, so i dont know how much improvement there was, but apparently if you are serious, you can soundproof the doors, tape up the rods, and connectors, you can make the door very silent when open/close and no rattles when speakers are being blasted
i wont be sound proofing as im going for some weight reduction but simple things like the sheet for moisture imo is a must.
thanks for the suggestion though!
