hi
what years civic wheels fit a 2007 sedan? are they all 4x100 15"? dad buckled 1x rim on his car so I want to know what years will fit
EDIT:I meant the STOCK 15" steelies from the poverty models, are they all the same across the years?
hi
2007 Civic (FD1) wheels are 5x114.3. I couldn't get your question..."What years Civic wheels fit a 2007 sedan?"
VTI & VTI-L: 16"
Sports: 17"
5x114.3
16 or 17 inch
This. Though pretty much any wheels can safely be fitted if they are:
Between 15 and 18 inches
8 Inches wide or less
Between 38 offset to 55 offset
This is only a general guide and you can fit bigger, more aggressive wheels with little to no modifications, however if you stick within the above specs then you can pretty much guarantee you won't have any issues. Check out the wheel fitting thread if you decide to go aftermarket. Lots of suggestions and specs of what people are running (and with more aggressive setups, what they needed to do to make it fit) and you can easily buy a set for not too much money.
sorry for the vague question I meant the STOCK 15" steelies from the poverty models, are they all the same across the years?
The steel wheels are the same from 2006 - 2011, 15x6 5x114.3.
specs on steelies for 2006-2011 15x6 with 195/16 tyres 5x114.3 civic vti
thanks guys just the info I was after
having trouble finding this spare rim. do other models share the same rim?
Have you tried wreckers?
Hey guy, look what i found for you
http://www.gumtree.com.au/s-ad/osbor...els/1017366819
Not quite what you're after.. but worth considering.
