i have an ap2 2007 model with a greedy turbo kit and its couldnt start now so anyone know about this stuff??
All you need to do is sapce your post out a bit. it was very hard to read.
Did your spark plugs, coil pack and injectors help with the stutering problem?
Have you got an immmobiliser issue?
Is the Fuel pump priming ?
yea sorry about the post
i just replace all of the spark plug and tested all of the coilpack and injector but everythings still working good but still not fixed the problem
i think its not an immobiliser issue becos the car engine still cranking whenever i pressed the start button
the fuel pump still fine buddy
Check your cat converter to begin with. Just to rule it out completely.
yea i will but my car's engine still turn over and keep on cranking whenever i pressed the start button so does it got anything to do with the ecu??
That sounds like it's not gettingn fuel (if the spark is ok).
yea it is bro so do u have any clue??
If it has compression, spark and fuel then it should start.
Get the car towed to your tuner I'd say.
Yeah if you exhaust all avenue then speak to the tuna
Could also be a vacuum leak somewhere on the manifold.
I had a bung go missing on my car not long ago, car would not start.
thank for all of ur help guys, just got i fixed by my friend mechanic and its all about the fuel so feel very good now,i just gave it a test drive and my weapon is come back, only cost me 100bux to fixed:)
