So I was driving today and from 2-3 Rd gear around 5k rpm there is a flat spot in my acceleration it's suddenly stops. It's as if I backed off the accelerator for a split second.
Can anyone shine some light on this topic for me
Thank you in advance
low oil
Has your car been tuned? what mods? Does it do it all the time or is this the first time?
Rbc manifold, injen cai .. first time it's done this. Every other gear seems to be fine no drop off
Maybe your fuel pump? I've had the same problem and it was my fuel pump fell off it's bracket and it was floating around in my fuel tank.
Seems to be getting worse on the way to work power was cutting in and out through the Rev range I'll sus out the fuel pump tonight. Will keep you posted
bad fuel, fuel pump, fuel filter
Changed oil on Friday definitely not oil.
might have got a bad fill of fuel from povo station?
Today motor completely turned off when I was accelerating out of a corner.. gave the fuel tank a tap from underneath the motor kicked over for a split second and died out so I'm certain it's the pump..
does it prime?
No voltage on the pump.
Problem fixed ****ed fuel pump.. getting replaced this afternoon
where did you get a replacement pump may I asked? I replaced mine with a 2nd hand one and I rather have a new one.
I Just replaced It with a Walbro 255 fuel pump paid $130
