Hey guys ive got a 97 5th gen vtir and got a minor oil leak from the vtec solenoid gasket
do you guys have any experience changing the gasket ?
cheers
cheers
youll vtec harder when you change it!
open it up and inspect the seals
clean the mesh nicely and get any gunks out
if the seals gone,replace
wherre can i get the seals guys ?
Reckon supercheap or autobarn might have it or will i have to order on ebay ?
thanks james found one on ebay http://www.ebay.com/itm/OEM-97-01-Ho...-/181387632221
they ad $20 for shipping ffs to send two rubber pieces in an envelope ....
ill try honda america
try hondapartsdirect
thanks mate
https://www.hondapartsdirect.com/index.php?p=cart i think i found em came out to be $19 dunno if thats with or without shipping . ive never used this site before
wuw just got the shipping quote $64 0_o so total comes up to $84
hahah probz might just ebay it i guess
If your buying from the usa of course shipping will be like that
You may as well add other parts to the cart that you may need/or need
As buy from america is still cheaper than buying from honda aus - even after factoring in shipping
yeh just bought it off ebay for $50 hopefully i ca put a stop to the leaking vtec solenoid :)
thanks Jasemas and curtis265 again
yeh bought it on ebay hopefully it wont be too hard to install :/
Just a heads up when changing the solenoid
Do it with a dead cold engine - that way the little 10mm headed bolts are not weakened by heat , and there isn't a bunch of oil ready to leak out when you take it off. Take it easy on the bolts. Undo slowly and tighten slowly too. Finger tight + a nick up with a small socket or spanner should do it
Thanks @bennjamin
will keep those tips in mind
