Anyone ever had their engine rebuilt? How did it turn out? is it worth it?
This is beyond vague...
It would help if you added some extra information like what car, what engine and what do you mean by "worth". Are you measuring cost to benefit or just overall quality?
car is an em1.
engine is b16a2.
Overall quality. Did it run well with no dramas.
Try to expland on why youre asking
do you need a standard oem rebuild due to engine wear/damage?
or rebuild for more power?
How many licks does it take to get to the centre of it?
Thanks for replies.
Yeah basically an oem rebuild due to wear and tear. 260xxx on clock. Head gasket is on it's way out. Basically wanna replace all that can be replaced.
Oh I was thinking it was d series
In that case I mean k series
And leeman said: "basically an oem rebuild due to wear and tear. 260xxx on clock. Head gasket is on it's way out. Basically wanna replace all that can be replaced."
This is where it's so frustrating being a noob. So perhaps it's worth helping to re-frame the questions?
The engine is listed as 160 hp (119 kW).
If for example, leeman asked for cost effective options for a daily, what would you recommend?
- head hone and refit at minimum cost ... $
- head hone and refit with major service, at minimum cost ... $
- all the bells and whistles ... $
- have a reputed workshop supply and fit and low km engine (imported), for over $1000
So, what does leeman want to spend and what does leeman want to achieve?
Best excuse to build a b20.
