Hi guys, today i locked my keys in the car while it was running (actuator problem). so i had to turn it off by taking two coil plugs out. everything has gone down hill since.
I had the nrma guy come and get the car unlocked, then another to try start the car.
The fuel pump works, it cranks over but i don't get a spark. The guy couldn't get to the obd connector (too much wiring) and couldn't reset the ecu.
I asked what it could be and he said it could be the immobiliser or the ecu however if it was the immobiliser then the fuel pump wouldn't pump fuel.
In the end, he took the negative terminal off the battery and said wait it out and in the morning try and see if resets the ecu. if it doesn't then it needs to be taken into a shop and rewired.
Its an integra Type R 2000 model. any help would be much appreciated.
EDIT: its never had start up problems till now.
