Hey guys, i couldnt find an answer to my problem when i searched this topic.
B16A2.
Bolt on mods, injen CAI.
Vision 2 1/4 headers, xforce hi-flow cat, skunk 2 catback exhaust.
Ive always had a problem with carbon build up on my rear bar from just 2 days of driving to work. Fuel efficiency is pretty bad aswell. About 300-350kms on a full tank.
I have changed the spark plugs, fuel filter, cleaned the air filter but still no luck. I checked the spark plugs a week after i installed them and it was already foul, very black and full of carbon.
So i decided to change the o2 sensor and reset the ecu. (Got the car to normal operating temp, turned it off, pulled the ECU and back up fuse out for 15mins, then put the fuse back in and started the car again for 15 mins. Turned it off then started it again)
Its still running rich now, i ordered a new set of leads because im pretty sure the ones on my car are still the same ones from factory and has never been changed. Hopefully it fixes my problem. Im sick of wiping my rear bar everyday after work lol.
If anyone has suggestions on what the problem could be and how to fix it,
it would be greatly appreciated. Or if anyone has the same problem/experience as i am having now.
Im just hoping i dont need to change a map sensor which i know are very expensive.
Im pretty pedantic about my car and have taken care of it, but i do give it a good rev out every now and then to clean out the exhaust.
Thanks in advance guys. :thumbsup:
