Bare minimum for engine swap
Hi all,
I want to use the driveline, ecu, fuelling etc out of a ITR DC2R for a kit car I'm building.
Now I want to keep the car wiring, lights, horn, brake lights, indicators etc separate from the ecu as much as possible, so my question is, what ecu do the DC2R's come with, and what are the bare essentials needed to run the motor?
Also I'd like to run and aftermarket dash such as the Haltech, Digidash or Aim dash, so is it possible to run these sensors (oil p, temp, tach, speedo) straight from sensors to dash, or does the honda ecu need the inputs.
My problem is to get registration I must run the stock ecu, intake, exhaust, fuel pumps and all emissions sundries, but I'm sure alot of these will "fall off" after rego, so I need to find out exactly what the ecu needs to run.
Am I correct in thinking the original DC2R ITR ecu is not compatible with Hondata piggybacks?
Are there any aftermarket ecu's that will handle the B18C7 as well as the honda ecu?
The car will just be my blat toy, and will be tracked 10-12 times a year as well, and will take the place of a westfield clubman I currently have.
So yea, atm I just need to know what are the bare essentials I need to run the motor, any advice is greatly appreciated!
TIA
Alex
