Dc2 Vtir 1994 sputtering on low revs, sounds like its miss firing.
Am I right to say the ICM and distributor cap are the problem?
Where's the best place to buy these? Honda?
Thanks.
Thanks.
Yea id say that would be one of the main this that stuff up easy... distributiorn and inside button... ordered cheap from auto one
Okay, so replaced the rotor and coil and still missfires at low revs.
Compression was good 210 all round.
Cylinder 4 spark plug was fouled (other 3 looked normal)
Anymore suggestions?
Change your spark plugs and check the spark plug leads, they may need replacing.
Another thing it could be is the throttle body.
o2 sensor maybe?
Replaced ignition coil, leads, dizzy cap and problem fixed.
Not sure why o2 sensor would cause 1 cylinder to miss fire?
Low revs sputtering sounds like o2 sensor, thats the conclusion i came to
At WOT the ecu takes info from the MAP
At slight throttle it takes info from o2
That's the way i interpret it
At least you got it sorted
Don't mean to hijack, but.... Mines been doing the same thing on my type r. If I'm granny-img and only light on the throttle it will bog down and die as though I'm running on low fuel. Once I open up to WOT, it runs perfect again. I've replaced the spark plugs, checked the cap and rotor, I'll try changing over my dizzy internals to oem tomorrow.
Ideas??
Update: Now on WOT the engine sounds completely different almost like a subaru but no lack in power.
Should I be worried?
You were spot on about the vac lines. Found the vac line that controls the butterfly in intake broken.
https://scontent-b-lax.xx.fbcdn.net/...74&oe=54F5400E
Not to mention it was a so damn hard to pull that out from under the manifold. I'm gonna superglue it and see how it goes.
Replaced my icm and coil. Appears to have fixed the problem. My rotor was also loose. Could that have been an issue??
Sorry. Wasn't intending to hijack. At the time I posted, my account was playing up and wasn't letting me start new threads. Continued to come up with this error. http://tapatalk.imageshack.com/v2/14...e9e5c27dc6.jpg
I had only assumed that he were finished. I apologised in my original post, and if the OP is upset then I apologise again.
Pulled injectors out today, they were dirty as shit.
Cleaned up, replaced fuel filter too and missfiring has gone completely, drove for about 30mins with no problems.
Did find a small crack on 1 injector tho, doesn't seem to be causing any problems yet.
https://fbcdn-sphotos-d-a.akamaihd.n...a006507fc7b81a
