Hey guys tonight's weather hydrolocked the engine or I think it did. How should I go on about fixing this ? Or would a new engine be better ?
THANKS in advance
THANKS in advance
New engine
Pm cbauto for engine, he just got a new sea container in with a decent range of low km engines
Same thing happen to me.
Does your motor still turn over?
Mine did but it didn't want to intially.
I changed the oil, Cleaned spark plugs and well, Cleaned coil packs,
Engine Flushed, New Pod filter.
I also took the headers off to make sure there was nothing in the exhaust.
Compression tested 215 across all cyclinders. Phew!!
Full tank of 98 + injector cleaner on my way home.
Did all of this on my hour break time in works carpark over nite :)
i was so worried. Car has returned back to normal, little better if anything new filter clean plugs.
with a hydrolocked engine, cant you pull out the spart plugs and try turn it over? blow out the water?
So if I want my engine to run 'a little better', i just have to hydrolock it
sweet as thanks for the info amant
10/10 would hydrolock again
Cbauto just called me he is crying what happened
Should probably get polo now
Polo can never hydrolock
Marco
wtb 335
Lmao groce
