I have done a search and couldn't find an answer to my question. What engine oils would you recommend for a Civic EG Vti and what is the engine oil stated in the instruction manual for this car (I don't have one :( )?
OEM.... ask ur honda dealer.... everyone will recomend that
mobile one 0-40 is good for vtec engine..: )
yep use honda oil would be first preference:thumbsup:Quote:
Originally Posted by aimre
or even something like magnatec
how much does the honda oem oil cost?
$31 5LQuote:
Originally Posted by civti
FEO Honda
LukeZen
engine oil works best mate :thumbsup:
get OEM honda oil - reccommended is FEO high performance oil.
$30 ish for 5l from your local honda dealer.
Probably the best oil to get.
Yeah cooking oil is no good.Quote:
Originally Posted by egSi
lol, nah man he should use honda brand extra virgin olive oil:pQuote:
Mobil 0-40??? WTF?? yeah if you want to change the oil every 2.5k, why not try motul 0w-20 in that case.
motul turbolight 10w-40, or technosythese 5w-40 should do the trick (these will require a fastidious oil change and new filter every 5k)
how much does a new filter cost? (sorry if that was a dumb question, but i'm still a car novice)
hey mate, check this out:Quote:
Originally Posted by azurenights
http://www.ozhonda.com/forum/showthread.php?t=17821
hey sorry to hi jack but i also jus wanted to know whats the best oil for an EG GL 92 model done 187xxx kms. i was told to use 15-40 but i wanted to use 10-30 feo oem honda oil cause its oem and its cheap hehe.
"azurenights" u can buy after market oil filters for 5-6 bucks from parts shops. i usually jus buy aftermarket cause i change the oil and filter every 5000km
I had a look at the Service Manual for USDM EG Civics and it said the following:Quote:
Originally Posted by .::F[L]Y::.
API Service Grade: Use "Energy Conserving II"
SG grade oil 5 W - 30 preferred
I would like to confirm with someone if that meant all EG Civics because it didn't specify which engine should use what oil.
i think the key word in that sentence is "preferred".
