Sorted
Sorted
Maybe its scared, ease up lad and try to make her more comfortable. Think before you drink.
have you confirmed it's shafts before changing them?
I'm pretty sure if you ask around here, we have more information than ur so called honda experts.
have you tried swapping wheels back to front, left to right?
have you tried pumping up the tires?
have you tried swearing at it?
have you tried to pm cbauto?
I'm shaw renzo would know what's the problem....
All sorted
No problem
I've got the hub rings on all wheels. I've even put the factory wheels back on to test out and still shakes. It's nothing to do with the wheels in this situation
I would assume its the shaft final thing..... be checking the rotors brake assembly, sussy assembly before saying its the shafts. If any mech has told u its the shaft without a proper inspection he anit no specialist.
If you were to change the shafts yourself...
1. Jack the car up, front will do. Put bricks on the rear wheels and use jackstands...
2. Remove Front wheels.
3. Undo the 36mm bolt from the hub end.
4. Remove Shaft from hub. Slides out. - Use big screwdriver or a crow bar.
5. Drive side you gota remove fromt he immedidate shaft and on passenger side from the box itself, Slides out. Use big screwdriver or a crow bar.
install is the other way around.
Also u can remove immediate shaft and drive shaft together if required. I found this easier. Some times it can rust in there and be a bitch.
If you dont have 36mm socket, go to a proper tool shop. I checked in 3 repcos/supercheap non had in stock waste of time.
I would also remove the kuckle I think its called from the shocks it will free up more space to slide the shafts in and out from the hub.
have you removed driveshafts before?
if you never done it before might be better get someone to do it
need few specialised tools like a punch, 32mm socket if base dc5, 36mm socket if type r, 1m+ breaker bar and ball joint separator
might need mtf fluid incase it leaks
might need new seals if you rip it
need new cotter pins for castle nut lower ball joint
probs around 200 bucks in tools if you never done it before
inb4amant "u dont even know met"
alignment wont shake always
i had funny toe settings on my prelude a while back, only shook when you took it over 120kph (like overtaking kunts in b16 crx)
maybe you are missing some weights on a wheel
swap back wheels to front see if still got issue or if the issue moves to the rear
Already tried that mate. Even tried with different sets of rims and tyres. Wheel balance and Alignment is great recently done.
How's the suspension and bushings?
How badly is it shaking?
No issues
engine mounts ok as well?
Yeah they look fine. Replaced one not long ago the rest look pretty good
