Sup guys just brought a eg and my mate got ek suspension with lowered spring. Will it bolt on or do i have to do mods for it to fit ?
Cheers guys
Cheers guys
couple of threads on here but if im not mistaken the front is same and the rear is dependant on the LCA
Yup.
Swap yokes over on the front and it will bolt in (ie put your yokes on the EK units). Rear will need different LCA's to fit.
Cheers guys
Want LCA's do i need to get ?
keep your lcas get the grinder out and grind the middle bushing for the tightass way. or buy press in an ek center bushing on the lca
or just buy ek lca. they go for dirt cheap anyways save you the hassle of screwing up or pressing new bushings in given the ones on the lca are fine
ahh soz guys was under the impression that the bushings were the difference
Cheers again guys.
So just buy ome EG LCA and they fit onto the Ek suspension ?
Yea mayb not grind it got 2 young kids in the car
Edit: Apparently the photo below is a DC2R (tho that's the type I have fitted on my EG6). EG LCA's are geometrically the same, so the length is wrong for installation into EK, or vice versa. EK LCA shown on the Bottom
https://lh5.googleusercontent.com/-E...o/IMG_4064.JPG
Edited and removed other photos to avoid confusion
thats dc2r lca not eg.
eg6 also had that lca
Yes I have EG6. Sorry wasn't aware it was different to other model EG's.
My bad.
lewl thats a dc2r eyelet lca and ek lca. all you need to do is change the center bushing where the suspension fork connects to an ek one
So i cant use ek suspension into a eg ? With mods ?
