I installed my Cusco Type I Bottom Strut Bar yesterday. I was asked not to post pics because of you having dial-up.
Cusco Strut Bar Install Pics
I will write a review later about it but I have not driven with it on enough yet.
Very nice!
Very keen to hear if there's a noticeable difference, did you have a strut brace fitted already?
Any particular reason why you didn't go for the more comprehensive Type II?
thanks
Rod
I've got the strut & type 2 on order.
I should be installing them this weekend. will let you know the result too.
Matell probably will give his impression first..:D
I am going to use the type I type II and upper strut
Provided I decide to go to QR on Saturday....;) Otherwise it will just be comments on any changes I feel in daily road driving...which of course will mean more to most people.Quote:
Originally Posted by baboo
It would be great to have some feedback on the noticeable differences from the Type I/II lower braces before the Honda R's Cusco pre-order finishes on Friday 6 May 05!! ;)
http://www.ozhonda.com/forum/showthread.php?t=19444
thanks
Rod
Nicely done, I'm considering the Lower Arm bar too but I'm thinking the other version with four points to compliment the Cusco front strut bar I've ordered...
Pleeeease let us know if you felt a difference :)
Me going to install this afternoon, will let you know the result Nick,
I've opt for version2, & strut brace. see if these can eliminate the creeking sound when I go up to my driveway. If it does, they certainly work!!
Cool! Let us know how stiffy is the ride at corners now :)
yes baboo, please do let us know how it goes.
are you installing the front or the rear sway bar?
I'm thinking to get the rear sway bar to complement my front strut brace. I'm not sure if the front sway bar is necessary.
Little bit of confusion there, Baboo's installing brace's not sway bars. The Type II strut brace he's installing does not replace the front sway bar. It acts in the same sense as the strut tower bar but connects to four mounting points on the underside of the chassis so the lateral, and torsional rigidity of the front of the car is increased. This increase in rigidity results in less flexing of the car's body, and in theory more responsive handling.Quote:
Originally Posted by euro77
hmm.. ok... I thought the version 2 goes to the rearQuote:
Originally Posted by Matell
This thread's worthy to be in FAQ, me thinks. *hint*
hello there
I followed your link in the ACURA TSX forums for this Cusco Type I Bottom Strut Bar installation. I looked at the last picture in the post and noticed the bar was very close to the CAT. Was it actually touching the CAT and if so, any long term damage?
Thanks
i got a type I also, no it's doesn't touch. i think only the typeII touches the cat
but if you have non standard headers, it might touch. One of this forum member use the DC headers and the flex pipe leaked because of touching/rubbing with the lower arm bar.
Question for all:
I will be getting the strut tower brace soon. To be installed on the Euro with standard suspension. Is it necessary to upgrade the suspension and/or install a bottom strut brace when i get the tower strut brace installed?
Do any of you have standard setup with just the strut tower brace? Feel any difference in cornering, etc?
my opinion... more for bling :P no need to upgrade suspension/ low arm brace because it's totally seperate, it is installed in the top of the engine bay
