Quote:
Originally Posted by bennjamin
Others - "bendix ultimates ($150 or so for front) are resin based - so will "warp " your rotor with excess resin melting onto the rotor after heavy useage - but the resin can be ground off easily.
Its just not adviseable to use RB74s or ultimates etc upon stock disc rotors...use "stock replacement" ( ie metal king etc) or OEM.
Just a fact... by all means get these upper mark pads- but they will not last as long , need time(see hard driving) to warm up , and have a high chance to stuff ur stocky rotors...(stock rotors,being solid will not dissipate the heat generated by these pads,(IE not designed for such pads) and thus over time in lots of warm-up/cool-down cycles they will tend to break.)
but gosh dam while the ride lasts it will be a fun one ;)
