I want to get some recommandation from you guys! is time for me to change clutch. What clutch should I choose?
OEM clutch
Deakin HD clutch
Deakin button clutch
and what's the estimate cost?
Thanks guy
OEM clutch
Deakin HD clutch
Thanks guy
what engine / transmission do u have ? mods ?
id think , best to get HD clutch - which consists of ( on dseries engines , might be different on b series etc) a stock clutch disc , and a slightly heavier clamping pressure plate ( 20+/-% increase in clamping pressure/torque transfer or so im told.
PM TODA AU on our forum for the latest prices on exedy kits to suit your car :)
Engine JDM EK4 B16A and the transmission from a EK4 as well
id go hands down for the exedy HD organic kit to suit your car. Apparently superior grip + longevity to stock or HD clutches :)Quote:
Originally Posted by Sitwy
u thinking of changin it 2 a twin plate ?
lol ?Quote:
Originally Posted by jdmlvn
I dun think I got that Heavy mod to affort for the twin plate. hehe^.^
can i use 3.9kg flywheel with a standard clutch?
why not ? altho the only 3.9 kg flywheel is the D series toda one afaik...:cool:Quote:
Originally Posted by z3lda
ORC make a 3.8kg flywheel for the B series.
and i'm sure a few other companies do too.
would stalling be an issue with that kinda weight on the average street car?
balance new clutch & flywheel b4 installing
Yeah there is no problem with using a standard clutch and a lightweight flywheel as long as you get it balanced. But you should be able to get heavy duty organic clutch for not much more than a standard clutch.
depends on what you use it for
if regularly street driven, i would reccommend getting no more than a HD organic clutch for ease of use. i personally have a diakin organic clutch (with lighter flywheel). Its fine for both street and strip. It cost around $600 fitted and balanced to the flywheel at a very reputable performance workshop, so really it costs no more than getting new standard clutch.
i think a oem honda delsol clutch is more then enough for the power that im puting out.Quote:
Originally Posted by CRXY01
i just want to accelerate faster plus have the soft feel of the standard clutch
bumpQuote:
Originally Posted by panda[CRX]
i have had a few ppl claim that lightweight flywheels have caused them to stall as there is less inertia due to it being so light, can anyone shed any light on this?
he prob can't driveQuote:
yea, i have never experienced this problem before. must be da driver man.
i was pretty much thinking the same thing, hence me asking for others experience
