Originally Posted by spardikis
look at the civic delsol gen2 (b16a2) head as it has pretty good (nearly the same as type-r) flow properties but a little less comp than the b18c. Also with the poor mans type-r look at your bottom end reliability....
balancing internals, different rod bolts and rods, oil reliefe valves, etc etc.... It's pretty hyped up and good if done properly, but look at the negatives as well. Its probably cheaper and more reliable just to go for the vtir bottom end with civic del sol head-combo. then thin gasket to rais comp.
