Hey guys... just wondering about whats involved in fitting DC2 VTI-R (B18C2) headers onto a DA9 LS (B18A)??? Is this possible and what modifications do i need to make??
AFAIK the b18a is a different dimensioned stud pattern to the other B series blocks (b18b/c etc)...so i THINK it is not compatible.
i COULD be wrong tho ! Anyone know ?
Oh man...i totally didnt wanna hear that. Had plans to jack -MuGen PoWeR-'s car tonight and steal his headers...grrr.... thanks ben. Any1 know for sure if these cant be easily modified to fit???
im pretty sure all b series are the same
and why would u wanna do it anyway ??
i dont think u would get any noticeable difference..
Dont put all ur eggs in my basket lol - im just "vaugely" remembering something for a few years back. B18b/c and b16a are the same exhaust port stud dimensions - Anyone know for sure ?Quote:
Originally Posted by TEG61E
nah i thnk your gettin confused with the intake manifold where the b18c2 is different to other b series
Sorry man, i forgot to mention they're 4-2-1 aftermarket headers :pQuote:
Originally Posted by FR33K
Yes it can be done but there is issues in regards to clearence of the Headers with the cross member, as far as I know the headers tend to also hang lower and you may also need to take the member off to make them fit!
Any exhaust shop should be able to help you out tho!
sounds like a bit of a tough job. I'll prolly just head out and look for a LS headers....thanks for the help guys!
Thats right LO N SXC
they will bolt onto the head fine
but you will ground clearance problems
All 4 into 1 headers will hang low I just got cutsom ones made up they sit up as high as they can but it is still the lowest point of the car
you will also have to cut up your front left to right cross member and remove your middel front to back member
i fit typeR header in my gsi b18b, just doesnt bolt up to cat. but i got the flange cut and rewlded the right way.
Not at all -for the forum database -no one has said if the port dimensions of the b18a are the same as the b18b , thus same as b16a/18c etc ?!?Quote:
A Gsi doesnt have any cross members like a LS you have alot more clearance and front room in that
2 issues you will have,
the bottom of the headers will hit the sump of a b18a,
and the lower portion where it meets the cat is shorter.
b16a headers wont fit on a b18a block as it hits the sump. Unless they are a mugen 4-1 copy headers where they are able to fitt all b series with the sacrafice of hanging lower.
4-1 copys also require you to notch and box section your lower bar.
I know because i have had all these headers and lernt by first hand experience.
im pretty sure that they fit, cause all b series engines are the same fit...
but if your wanting some dc2 vtir headers. i got some laying at home if your interested.
with the heat shield. but these should fit striaght on.
b series are not all the same fit, the b18a is the exception.
Correct me if i'm wrong but i think the 02 sensor is in a different position for LS?
Just ordeer a set from X-Force, speak wit EGSI from here on Ozhonda, he will hook you up and he has great bloke to deal with.
yes it id you might have to extend the wireQuote:
Originally Posted by bennyBear
in an LS its only one so thats pretty easy
