will the motor run ok with the factory map sensor if it gets fed boost.
when can i get a 2 bar sensor from??
factory map sensor can read 11.7psi of boost
The STD Honda map sensor will handle 11psi of boost.
ALLMTR996
kool,
i wont be running that much.
is a apexi safc2 ok to tune a low boost intercooled setup on a B18B, with stock pump injectors?
upgrading them later but wanna get motor turboed 1st.
looking at crower turbo cams aswell
if u want to use an afc, get 440cc injectors atleast. its called a hack and needs double the size injectors otherwise ur computer will throw a cell..
an emanage on the other hand can handle stock injectors.
while an safc will "work", it's a VERY poor option
hondata/uberdata/chrome/whatever other ems floats your boat is a far superior choice
Is there an echo in here, LOLQuote:
Originally Posted by ALLMTR996
Yes, but your motor cant....Quote:
Originally Posted by Weq
either way, you need to upgrade injectors
would 450cc injectors be good for 300fwhp????
yeah, should be, if you need to, raise the fuel pressure.
Quote:
Originally Posted by ProECU
i beg to differ. i know of plenty of sohcs running greddy kits, which have lasted alot longer (read; muiltple years, still going) then alot of built engines running standalones. its all about the limits and what you are happy with.
Yes grasshopper.Quote:
ALLMTR996
Perhaps. Let me clarify..I was refering to running stock injectors on a stock turbo motor (that was the original point)Quote:
The motor will not cope with a lean condition, which stock injector will most definate cause under boost.
Honda run injectors at over 80% duty cycle from factory.
And even though you could probably push them to 90+% duty cycle, its not such a great idea.
And even if you did, we're only talking capacity for about 2psi boost at the most.
I wouldnt be happy with 2psi boost after spending a few thousand for a turbo kit.
fair enough :)
