hello people...
i just wanted to know the difference between the egs...
i got a civic vti 94 model... which eg is this..
is there any different shapes to this.. = )
thanks
hello people...
thanks
Yeah i'd like to know too so I can start getting some JDM parts for my EG sedan.
-Kappa
All the shape are the same, just diff spec and engine.
EG6 is Civic SIR hatchback B16A (import)
EG4 should be Civic Gli hatchback D15? (local)
EG9 Civic SIR sedan B16A (import)
your one should be a Civic Vti D16Y, EH9 for sedan, not sure what it is for hatchback.
Check your VIN no, or your rego sticker.
Should say it
Check your vin to see what model you have ;-)
B16 is the EG6 3D. EG4 came as VEi in Germany SOHC Vtec and something else non-vtec. EG5 was the ESi SOHC VTEC.
Wait ... I'll copy you the list:
EG1 JDM D15B 96 kW (130 PS) 2D del Sol AT/MT Disk/Drum 1.5VXi [checked]
EG1 USDM D15B7 2D del Sol
EG2 EDM B16A2 118kW (160PS) 2D MT Disk/Disk 1.6VTi (del Sol) [7100-485] [confirmed]
EG2 JDM B16A 114 kW (155 PS) 2D AT Disk/Disk 1.6SiR [checked]
EG2 JDM B16A 125 kW (170 PS) 2D MT Disk/Disk 1.6SiR [checked]
EG2 USDM B16A2 2D del Sol VTEC
EG2 USDM B16A3 2D del Sol 1.6
EG3 EDM D13B2 xx kW (75 PS) 3D [7100-480]
EG3 JDM D13B 63 kW (85 PS) 3D AT/MT Disk/Drum 1.3EL [checked]
EG4 EDM D15B2 xx kW (90 PS) 3D MT Disk/Drum 1.5 [7100-482]
EG4 auch mit D15Z1???? 1.5LSi, VEi, VTEC-E
EG4 JDM D15B 69 kW (94 PS) 3D MT Disk/Drum 1.5ETi [checked]
EG4 JDM D15B 74 kW (100 PS) 3D AT/MT Disk/Drum 1.5MX [checked]
EG4 JDM D15B 96 kW (130 PS) 3D AT/MT Disk/Drum 1.5VTi [checked]
EG5 AUDM D16Z 100?kW (xxx PS) 3D MT Disk/Disk 1.6Si
EG5 EDM D16Z6 92 kW (125 PS) 3D MT Disk/Disk 1.6ESi [7100-478]
EG5 EDM D16Z6 92 kW (125 PS) 3D MT Disk/Drum 1.6ESi
EG6 AUDM B16xx 118 kW (160 PS) 3D MT Disk/Disk 1.6SiR
EG6 EDM B16A2 118 kw (160 PS) 3D MT vent.Disk/Disk 1.6VTi [7100-477]
EG6 JDM B16A 125 kW (170 PS) 3D MT Disk/Disk 1.6SiR/SiR II [checked]
EG6 JDM B16A 114 kW (155 PS) 3D AT Disk/Disk 1.6SiR II [checked]
EG7 JDM D13B 63 kW (85 PS) 4D AT/MT Disk/Drum 1.3EL [checked]
EG8 AUDM D 88 kW VTi
EG8 EDM D15B2 (auch asl D15Z1??) xx kW (90 PS) 4D [7100-481]
EG8 JDM D15B 67 kW (91 PS) 4D AT/MT Disk/Drum 1.5ML
EG8 JDM D15B 69 kW (94 PS) 4D MT Disk/Drum 1.5ETi [checked]
EG8 JDM D15B 74 kW (100 PS) 4D AT/MT Disk/Drum 1.5MX [checked]
EG8 JDM D15B 96 kW (130 PS) 4D AT/MT Disk/Drum 1.5VTi [checked]
EG8 D15B7 USDM All 4-door DX/LX
EG9 AUDM B16xx 127 kW (160 PS) 4D MT Disk/Disk 1.6SiR
EG9 EDM B16A2 118kW (160PS) 4D MT Disk/Disk 1.6VTi [7100-476]
EG9 JDM B16A 114 kW (155 PS) 4D AT Disk/Disk 1.6SiR [checked]
EG9 JDM B16A 125 kW (170 PS) 4D MT Disk/Disk 1.6SiR [checked]
Just in case you want to have the EH/EJs as well:
EH1 JDM ZC 77 kW (105 PS) 4WD/AT/MT Disk/Drum 1.6RTX [checked]
EH1 JDM ZC 96 kW (130 PS) 4WD/AT/MT Disk/Drum 1.6RT-Si [checked]
E** USDM D15B7 102 PS 4D MT Disk/Drum ? 1.5LX
EH2 EDM D15Z1 68 kW (92 PS) 3D MT Disk/Drum 1.5VX
EH2 USDM D15B8 70 PS 3D MT 1.5CX
EH2 USDM D15Z1 92 PS 3D MT 1.5VX
EH2 USDM D15B7 102 PS 3D MT/AT 1.5DX 2hgeh2451nh515335
EH3 USDM D16Z6 92 kW (125 PS) 3D MT Disk/Drum? 1.6Si
EH6 USDM D16Z6 2D del Sol AT 1.6Si
EH6 USDM D16A8? 2D del Sol MT 1.6Si
EH6 USDM D16Y7 2D del Sol 1.6S
EH6 USDM D16Y8 2D del Sol 1.6Si
EH9 EDM D16Z6 92 kW (125 PS) 4D Disk(240mm)/Disk non-ABS 1.6ESi [7100-479]
EH9 USDM D16Z6 92 kW (125 PS) 4D MT Disk/Drum? 1.6EX
EJ1 CDM D16Z6 92 kW (125 PS) 2D MT Disk/Drum 1.6Si
EJ1 EDM D16Z6 (125 PS) 2D MT 1.6ESI [1153-305]
EJ1 JDM D16A 96 kW (130 PS) 2D MT Disk/Drum 1.6 [checked]
EJ1 USDM D16Z6 92 kW (125 PS) 2D MT Disk/Drum 1.6EX
EJ2 EDM D15B7 74kW (101PS) 2D MT Disk/Drum 1.5LSi [1153-306]
EJ2 USDM D15B7 75 kW (102 PS) 2D MT 1.5DX
EJ3 JDM ZC 96 kW (130 PS) 4D AT Disk/Drum 1.6EXi
EJ4 JDM D16A 96 kW (130 PS) 2D AT/MT Disk/Drum 1.6VGi
Sadly I haven't been able to confirm every model yet.
I have a 94 hatch, full import, b16a, all disc, all the interior goodness, so which is mine? and what does checked mean? just curious.
thanks guys
dam thats alot of eg's
that means I have been able to confirm its existence. It should be an EG6 then. The numbers for instance like [7100-477] are the registration numbers in Germany 7100 is the manufacturer 477 the model. It means I have confirmed that particular model in the german automotive registration jungle ;-)
Hey mate,
So what would a 92 Si EG Sedan be? D16A8 I believe.
-Kappa
EG5Quote:
Originally Posted by kappa1st
EH5/8 (one or the other)Quote:
Originally Posted by type one
yup its a EH8 i believe. Hatchback VTI and SI are EG5 -
Oh guys, you are giving me hope. Can anybody confirm EH5 and EH8s existence (vin plate would be great) .... Is that an AUS model? Never heard of them so please give me the specs:Quote:
Originally Posted by bennjamin
EH5 AUDM ENGINE kW ( PS) 4D Disk/Drum? 1.6???
EH8 AUDM ENGINE kW ( PS) 4D Disk/Drum? 1.6???
Oh please, can some sedan owner look at his vin-plate and copy it or take a picture of it or the like. Please, please pretty please.???!
EH9? (92-93) AUDM D16A8 96 kW 4D AT/MT Disk/Disk 1.6 DOHC NON VTEC Si
EH8? (94-95) AUDM D16Y1 96 kW 4D AT/MT Disk/Disk 1.6 SOHC VTEC VTi
EG5 (92-93) AUDM D16A8 96 kW 2/3D AT/MT Disk/Disk 1.6 DOHC NON VTEC Si
EG5 (94-95) AUDM D16Y1 96 kW 2/3D AT/MT Disk/Disk 1.6 SOHC VTEC VTi
yeah thanks guys..
that means mine is an EG5...
hehe
doesn't existQuote:
Originally Posted by chartinael
my Civic Si D16A8 is EH9
oops missed the sedan part...
missed the sedan part and i am psychic i knew you had a hatch hahaah.Quote:
Originally Posted by Honda_Pda
What do you mean doesn't exist. I know it exists ... are the specs wrong? I am uncertain of the engine code but fairly certain of the chassis code.Quote:
Originally Posted by saxman
bumpety bump still waiting for definite EH5 EH8 owners to show their vinplates ...
The EH6 is the del sol with the d16 in it, however, there was never an eh6 in the usdm market with a d16a8Quote:
Hey guys,Quote:
Originally Posted by civiceg9
Had a look in my engine bay and it definitely is an EH9.
-Kappa
what part of the VIN tells you what kinda EG it is ???
i got told mine is an EG4 but the vin starts like this
JHMEG33.... etc
well, please tell me the engine code of the EH6 D16??? All you do is say it is incorrect. If you do own a USDM EH6 please take a picture of the VIN plate. It has the engine code underneath the vin.Quote:
Also, according to the vin o page 2 it is not an EG4 but an EG3.
jhmEG3 .... those are the digits needed to verify chassis.
kristin
there were three eh6 codes listed, only two were correct. For 93-95, the EH6 was the del Sol Si with the d16z6. For 96-97, the EH6 was the Si with the d16y8 and the S with the d16y7.Quote:
Thank you, but according to my info did the automatic and manual Si have different engine codes. As far as I know the AT has the Z6 and the MT the A8. Can you also provide the HP for the USDM models?
kristin
the automatic and manual engines were the same. My si is manual and has a d16z6 in it.Quote:
The d16z6 is rated at 125hp @ 6600, 106 ftlbs @ 5200
the d16y8 is rated at 127hp @ 6600, 107 ftlbs @ 5500
the d16y7 is rated at 106hp @ 6200, 103 ftlbs @ 4600
