What do you need to fix the Vtec pressure valve for a b16a?
My engine light goes and i checked it doing the paper clip trick.
Anyone know how to do a DIY on this? Or i can just fix the problem with just buy another vtec solinoid?
first thing I would do is check that you have enough oil in the car... low oil will result in low oil pressure, which will trigger that code
you need to do a continuity test on you VPS, you should have continuity when not in Vtec, when there is pressure on the VPS the continuity will go away
vps?
There oil in there i just changed the vtec for it it the other day..
its kicks in when im driving.. it turns of and on i thought i had a loose wire i checked everything and everything was ok.
Vtec Pressure Switch
its a switch not a valve, BTW im talling about the switch that senses the change in oil pressure when Vtec kicks in. code 22
yeah thats what it is code 22.
just need to do a continuity test aye...
yeah when im driving my engine light kicks on and my car feels like its gonna stall and my dials switch on and off.. i get scared lol
DjRob: Are you talking about the...
VTEC oil pressure switch? (normally green sensor)
or
VTEC activation solenoid? (actually engages VTEC, looks like a C battery)
call me Rob...
i done the ECU check and it keeps on beeping code 22..
ECU MAN said its the switch..
Hey Rob,
If so, replace the switch with a secondhand one. Common part for B16/18 & D16 VTEC, I think even the H22 has it
Just ask for the green sensor under the Dizzy if the wrecker does not know what it is.
Honda OEM, they want an arm & a leg for it.
yeah? i was just thinking of going to Honbits on the weekend but looks like im gonna go now. I know which switch it is.. right under the solinoid. I couldnt even reverse it in the car park this morning. It kept on stalling and engine light clicking away.
i just got a new clutch put in i thought the mech farked up my car till i checked the ecu codes
2 long ones and 2 short ones
Thanks man i will do that if it doesnt work i'll just take it to the mechanics i cant do a DYI if i dont know what im doing hahaha
Get the mechanic to check over the clutch, just in case.
I paid about $25 for my switch, as it broke off my engine during freight.
check that its plugged in correctly.
yeah i did yesterday. that wire snapped when i done the coversion in my eg. I chekced it yesterday and replaced it with a better plug but still kept on stuffing up.
