the 10w40 anyone use it in their civic?
Nope but I use Motul oils for all my bikes, and am more than happy with them. At the end of the day though, I think they aren't as necessary unless you're running a fairly aggressive setup. If you've got the $$$ to spare by all means, but there are cheaper alternatives that will do the job as well.
BTW: do they rate Motul car oil the same as motorbikes? I.e 510, 6100, etc, or is it just one generic range with different weights?
yep they sure doQuote:
Originally Posted by crx2gen
i find it ok after my service with that oil.... feels more free
wat oil rating would u normally use for a 99 civic vtir?
Here is a quick rundown of MOTUL oils
100% Synthetic
8100 E-tech 0W40
8100 Eco-nergy 5W30
8100 X-cess 5W40
Technosynthese Synthetic
6100 Synergie 15W50
4100 Power 15W50
4100 Turbolight 10W40
Mineral
4000 Motion 15W50
4000 Motion 10W30
2000 Multigrade 20W50
2000 Multidiesel 15W40
8100 X-cess 5W40 or 4100 Turbolight 10W40Quote:
Originally Posted by kEnsHi
I dun like 4100 .. never tried 8100
but I am using 300v , 10-40W
going to try Castrol 5-30W R syn.
as autobarn sell them cheap now... only 3X for 5 litre..Repco still sell them at 6X for 5 litre
had been using mobil 1 fully syn 5-50W for a long while already ..
get bored ...
What gear oil shoul u use in an ITR gearbox ?
Check your user manual ;)Quote:
Originally Posted by Civic Type R
i would recommend redline shockproof gear box oil ! its awesome !Quote:
whats a good engine oil for my civic si? l'm using the honda oil 10-30w, but i think mobile fully syn is better.
What u guyz rekon ?
i am planning to use Mobil 1 oil 5-50w in my B18c but my friend said to use some other Mobil 1 oil 10-30w instead... which one do u guys reckon?
what does the 5 part and 50w part mean?????
what are some beter oils then MObil one oil 5-50w??? and where can u get them?
thanks
??????????? can anyone help. im gettin my service tomorrow
5-50W
5 is the starting viscosity .
50 is the working Viscosity.
If U REV your car to 8500 quite often .. then choose the engine oil at 30-40W
if not , then 50W is fine.
for track , it is okay to use 0-40W. However, NO good for ROAD use and need to change the engine oil atraight after the track day.
for Road Use, I prefer 10-40W. Less harm to the engine in the morning ( cold start ) .
I recommend Motul 300V 10-40W. although the engine will EAT a lot of engine oil , need to check regularly.
lol might be a bit late... but just go to hanny's in smithfieldQuote:
Originally Posted by Dvius_Honda
Mobil 1 10-30W sitting in drums there.... just take an empty bottle.
10-30W isn't available everywhere....
Motul is good as well.. autobahn chatswood has it on the shelf...
just depends where you are. It's not sold everywhere.
It doesn't really matter what oil you use, just change it regularly.
I'll still dump a mineral oil in my car (although new cars shouldn't need it, it was reported that mineral oils were better for seals) - then if I drive it hard, change it around 2500kms to a synthetic.
i went th other day to buy some Motul Oil, but didnt end up getting anything cause i didnt know which one to get, and the guy was no help, obviously not knowing shit all about honda's....
Which Oil do you recommend me to get for my 96 EK VTi-R? The cops a good rev daily....
A bit late but go Mobile 1 15w-50
Reason is it is a thick oil......takes longer for it to get to temp but will protect your engine a lot better than other grades cause of our hot climate and, i'm sure you to your service every 5000km . 15w-50 is what southen people use when taking there cars on Track days. eg(WRX's)
i got the Motul Turbolight 4100 10W40..
its a lot smoother nows.. so i gues its all gud :D
castrol 5w-30 gets dirty very quickly... i find i need to change it every 4k... and im not in vtec that much at all...
currently using motul 10w-40 technosynthese 8100... im pretty happy with it... its what spoon uses LOL... actually they use the good stuff the 300v... but its $20 more expensive :(
i would recommend either... anything in a 5w-30 or 10w-40 range is fine for a civic.
i only eva use motul oil.. its the only oil that lasts in my engine.
i use the le mons 15w60 300V which you can only get via speical order... its great stuff..
Regards James
seriously i thought oil is oil...if you are comparing the same grade of oil of course...its all branding to me neways
I use that stuff too :)Quote:
Originally Posted by rocky_b
300v is soooo expensive as a regular service oil though.. better be in the industry like blkcrx is.. otherwise your paying too much to get you to work and back
I've used 300v, Xcess 8500?, Turbolight. Good oil, but I've found another brand that works better for me.
And its expensive for regular oil changes.
