hey all,
i just bought an emanage. its just the main unit, no wires ect....
what harnesses do i need to run it on my turbo d16?
just the ignition and timing harnesses?
hey all,
u need the ignition harness and the main unit harness
the fuel harness is simply added wires to the main harness, so dont buy that, and use the spare ignition harness wires to plug into the main harness
gl with it
does anyone know where to get the main unit harness?
so i dont need the timing harness pornstar?
Ignition & timing is the same thing, just different words :)
heist, ur ghetto.
The harness plug is from a rx7 (series 3?) headunit. other then that, just ghetto up something urself. Dont buy any ;). Checkout the yahoo emanage group, plenty of info there.
Iginiton harness is just 2 wires. u need ingition, injector and main (airflow) harness.
heist, if ur not going to make up ur own, u only need the main unit harness and the ignition harness (because it has the plug for it), the injection harness is not needed, as its simply just added wires to the main unit harness!
Weq is simply taking the logic further and making the complete harness, using the right plugs. In many ways, its pretty easy to do if u have the plugs.
if u need help u can pm me directly or contact me by phone.
pornstar: i like the injection harness because u can directly add to the amount of fuel injected, without spoofing the airflow signal. this leads to alot LESS timing alteration when the tune is said and done. AS a min main and injection IMO :)
Read up my first post... the fuel harness is added wires to the main unit harness, so if u want to buy a "harness" for the plugs, i said get the ignition, and use the leftover for the injection "harness" which is added wires.
IE I know what u meant, u just misread me :)
yep sorry. im stupid head. ;)
if you want go to your nearest autobarn theyre a Gredyy/Trust dealer also.
Quote:
Originally Posted by Weq
so weq, ur telling me an rx7 headunit plug is the same as the emanage MAIN plug?
plug and play e-manage harness avaliable from boomsland.us
http://boomslang.us/emanage.htm
$139USD
Boomslang Plug'n'play products work perfect everytime and are the best built products you will find,When you work out the cost vs the stuffing around making stuff up I would use one of the products anytime.Keep in mind that if you take your car to get tuned and your home made harness is not doing its job you will get charged for the time that is being wasted trying to work out the problem and then you still have to pay for the tuning time on top of that,and the $ will add up very quick.All I'm saying is spend a little more now and do it right and it will be cheaper in the long run and less frustration for the tuner.Quote:
Originally Posted by Bowzer
Regards Dyno Dave
dave is right. the most anouying part of the emanage is the damn installation. u gotta make sure everything is working and connected right before taking to a tuner. this includes loading up the software on the computer and setting everything up. More then a few times i have been left wondering why the TPS isnt regitering properly, then after hrs of fiddling with software i finally get it going..
so u reckon shell out the mulah for a boomslang harness? it kind of kills 2 birds with one stone.....but a very expensive stone lol....about 250 aus...
heist, ur ghetto. u can wire it in no worries. just double check everything before taking it to a tuner like i said.
