as title states :)
as title states :)
What model engine?
DOHC SOHC?
Which part are you not sure about?
hardest/trickiest part would be getting your timing belt on correctly and torquing up the headbolts and the camshaft installation.
Ok then again that is the main thing that is involved LOL
lol, thanks guys. Looks like something i should leave for the machanic then.
B-serious preferably
It also depends on how hands on you are and if you've done anything 'mechanical' before. I'm sure someone can post up a service manual with some pics if you want :)
pft
peice of cake
only problem is I dont do them enough to make a DIY. Honda Head gaskets are to reliable :)
do nissan heads all the time though :)
anything in particular you wanted to know...
*throws book at wall*Quote:
Originally Posted by ECU-MAN
I thought you stopped doing Nissans after that mess in your garage.
But a headgasket change DIY would be a nice addittion *hint*
I have a lot of online manuals that I can post here but I don't want ot post a lot of pics and take up all the space! What make and model, better yet engine code?
make sure the cams are locked in place
fly wheel locked in place and belt marked out on cams and belt to c if the crank moves etc.
disconnect intake manifold .. nething that connects to the head ..
then im thinking the head is machined flat and the block is prepped...
new gasket put on block with a bit of red loctite gasket sealer then put ur head back on
then put ur timing belt back on making sure the marks are all the same
remove locking bolts from cams and flywheel
wind the crank over 2 times to make sure everything is ok and not hitting on anything.
then install everything bak on.
thats what i believe is involved.
and dont forget to set the timming,
and fill up yoru coolant and change your oil and oil filter
nice one EG5 + Rep for yal
PS Wyn
next honda head that comes along
Ill do a real nice DIY for you, but you will be waiting a long long time :)
thanks ecu man...
forgot about that .. lol
remember the torque sequence to guys
+ Rep for 2
