hey i got some fog lights off one of the guys on here but there was no instructions how do i fit them anyonw have any instructions for them as i would like to fit them tomorrow i tried today but dunno how they go?? PLEASE HELP!!!
Rgds.
Rgds.
The simple answer is you have to cut your bumper.Quote:
Originally Posted by LowEk
Let me see if I can dig up some instructions for you.
Ok, here you go:
http://www.hondaautomotiveparts.com/.../19796_01.html
hey thanks man.
No problems. Let me know if you have any questions/need any help.Quote:
hey got the lights fitted but now the black cover does not fit properly has a lil gap on the top and the hole on the cover and the bold hole on the bracket dont line up?? also got it all working the foggies worked for like 2 mins then now they dont work hooked it all up righ i think?? also should the light switch always have a light on not the one to say its on just so u can see the swith?? should the 2 little brown plugs be pluged into the fuse box if so does it matter what plugs on the fuse box??
Rgds.
Fitment - you might have the left light hooked up to the right side and visa versa. Is the kit genuine? If it is it should all be plug and play - very simple.Quote:
What do you mean about the dash lights? They always stay on?
the right is on the right and vise versa. kit is aftermarket got it off 02zzi he got it from the US but it is plug n play same as the genuine kit. its only the light on the foggie switch thats stays on even when i dont have the key in the IGN??
I havent tried mine without having the ignition on. Will try it later and see if it works.
i dont mean that they work wothout power just the light on the swith stays on without keys in the IGN.
If I understand you right - no, it shouldnt do that.Quote:
yeh that what i thought but i think i connected everything ok??
where should the 2 brown i think female plugs go?? into the fuse box??
Are we talking underdash or underbonnet?
under dash.there is no wiring that i had to do between inside the car to the front bumper (run wires just connect 3 wires up under the dash.
Hmmm, I am not really sure about why that would be a problem. Did you connect it up like in the OEM install or somewhere/somehow different?
An option might be to take it to an auto electrician (if you cant figure it out) and get them to sort it out.
got the lights working now i just got no dash lights hopefully just a fuse but ill find out tomorrow. Thanks.
fixed the problem with the dash lights it was only a small 7.5 amp fuse. thanks for helping me with this Zdster.
NP. Glad you got it sorted out :thumbsup:.
