Originally Posted by dave_ed9
The pedals are closer, but the RHD cable is also shorter. Too short. And, if you somehow got ahold of a LHD one, it'd be way too long.
Yep, I used the hasport mounts to do mine, would recommend them. Its quick and I'm very happy with it.
The other main thing hasport didn't consider with RHD cars is power steering. If you want to keep it you need to cut a heap from behind the left headlight bracket to clear the compressor, then get a hydraulics place to make you up a custom high-pressure hose to suit the b-series compressor connector. It cost me around $100 for this hose, and you need to make up another short low-pressure hose for the oil feed.
