have i distorted my sump gasket.. or is it ok? [pic]
Hey guys.. just replaced my sump gasket on my b16a1
I am just concerned that i may have distorted the gasket too much which may lead to leaks..
http://i1.tinypic.com/nq8ubo.jpg
Basically when i removed the sump most of the bolts were quite loose (imo).. like i would do 1/4 of a turn with the ratchet then i could remove the ratchet and undo the bolt with the socket.. Also it looked as though the gasket has been previously replaced/fixed because there was gasket sealant all along the gasket..
So i basically cleaned it all up.. put a new gasket on with the bolts finger tight, then 80kg.cm then 120kg.cm torque (followed instructions from the integra b18 manual).. but yeah as u can see from the pics looks like it may be distorted/coming out too much (in quite a few spots)..
or is this all fine?
manual info:
http://tinypic.com/mbk6qu.jpg
