Originally Posted by Shraka
Unless you plan on upgrading the conrods, boosting a Honda engine generaly isn't a good idea (unless you don't mind blowing your engine up eventualy). Sure it'll make good power untill to goes pop, but the conrods on VTEC engines are light weight to get the revs happening, and not strong enough to deal with decent boost. At least, this is what I hear.
As for the Type R head, why not get a Type R block too? Better (lighter) conrods and higher compression.
Alternativly, as has been mentioned, get the Type R plenum, New lumpy cams, new valve springs, port and polish (carefull who you go to), extractors and exhaust. You might also want a lightened flywheel (I know my integras flywheel is as heavy as an Elephant with a penchant for junk food) clutch and suspension work.
My take is an atmo 1.8ltr is never gonna make massive numbers. I'd focus on suspension first, if you haven't already. My Integra handles like a monster even on stock suspension. Put coilovers, new sway bars, tower strut braces and a Type R LSD in the front and not much is gonna be able to out corner you.
